  • Tormek T-1 Kitchen Knife Sharpener (bara maskinen)
  • Tormek T-1 Kitchen Knife Sharpener in a kitchen with women in background
  • Outdoor Honing on Tormek T-1 Kitchen Knife Sharpener
  • Tormek T-1 med separat bryning på brynskiva i kompositmaterial med integrerat polermedel.
  • Magnet som samlar upp stålpartiklar från slipningen och patenterad styrning. Tormek T-1
  • Knivslipen för hemmakocken med finkornig diamantslipskiva för professionellt resultat.
  • Rejält trähandtag i massiv ek behandlad med hårdvaxolja.
  • Tormek T-1 Kitchen Knife Sharpener har en snygg, subtilt industriell design som ger den en given plats i köket.
1 of 17
Regular price
£330.00 GBP
Regular price
Sale price
£330.00 GBP
Tax included. Shipping calculated at checkout.
In stock – Estimated delivery within 1-5 business days
The first real knife sharpener for the home chef. Unlike a simpler sharpener, hand lapper or honing steel, it sharpens the entire bevel of the knife, not just the outer edge. With the Tormek T-1 Kitchen Knife Sharpener, you’ll never have to send your knives out for sharpening – you can easily get them to professional sharpness yourself in a matter of minutes. At home in your own kitchen.
Selected Features
  • Precise setting of the sharpening angle with the patented guide.
  • Fine-grained diamond grinding wheel for professional results.
  • Composite honing wheel with integrated polishing agent for razor sharpness.
  • Minimal material removal – you don't grind away more steel than necessary.
  • Quiet running – only 45 dB
  • Powder-coated housing fully cast in zinc, with a sturdy oak handle.
  • 8-year warranty – 5 years + 3 years extra with online registration (for household use only).
Home Chefs Deserve Professional Sharpness Too
The T-1 Kitchen Knife Sharpener has a sleek, subtly industrial design that gives it a natural place in the modern kitchen. Because whether you're cooking in a restaurant or at home in your own kitchen, the chef's most important tool is not a knife, but a real knife sharpener.
Sharpen your kitchen knives
With its innovative design and the best materials, the Tormek T-1 Kitchen Knife Sharpener can sharpen most types of kitchen knives. The patented guide can handle knives with blades 12–60 millimeters (0.5–2.4 inches) high and up to 5 millimeters (0.2 inches) thick, with unlimited length. The fine-grained diamond grinding wheel sharpens all types of steel to professional sharpness and can also sharpen ceramic knives.
Quality and Care
The Tormek T-1 Kitchen Knife Sharpener is designed for those who care about quality and want to take care of their equipment. The machine is built to last and comes with an eight-year warranty, but will likely keep you sharp for much longer than that. With minimal steel wear, the life of your knives will be extended, and it will always be a pleasure to use freshly sharpened, razor-sharp knives in the kitchen. That's why a word of warning is in order: there's a good chance this will become your new favourite gadget.
Technical specifications
MEASUREMENTS
Width 204 mm (8")
Depth 196 mm (7 ¾")
Height 181 mm (7 1/8")
KNIFE MEASUREMENTS
WEIGHT
Incl. packaging 6.2 kg (13.7 lbs)
Machine only 5.4 kg (11.9 lbs)
GRINDING WHEEL
∅ 150 × 18 mm (5 7/8" × 5/8")
Max 200 rpm
HONING WHEEL
Composite, ABS plastic
∅ 160 × 30 mm (6 ¼" × 1 3/16")
HOUSING
Precision-cast housing in powder-coated zinc
Bottom in impact-resistant plastic
Handle in solid oak treated with hard wax oil
MOTOR
Single-phase, AC-motor
120 W (input power)
Recommended operation 30 min/h
Maintenance-free
Quiet running, 45 dB
10 000 operating hours
CORD LENGTH
1,7 m
PATENT
To see all patents, please visit
tormek.com/patents
Knife Protection Pads – One additional set
Edge Protecion – 1x 30x305 mm, 1x 60x305 mm
Tormek Edge Marker - One Tormek Edge Marker to find the right angle
Instruction
Getting Started information
TRY THIS AT HOME
The fine-grained diamond wheel is optimized for razor-like sharpness, so we have just one small warning: There is a major risk this will become your new favorite gadget!
  • 1. SET PREFERRED EDGE ANGLE
  • 2. SHARPEN ON BOTH SIDES
  • 3. HONE TO A FINAL FINISH
    Remove the burr and polish the knife on the honing wheel to achieve a razor-sharp edge.
Customer Reviews
Based on 1360 reviews
86%
(1167)
9%
(119)
3%
(37)
1%
(15)
2%
(22)
P
Patric Lövlund
Skulle köpt tidigare
Kanon, Lätt att slipa på och blir bra
T
Timo Lehmann
Sehr zufrieden
C
C J Wood
Awesome product
Very glad I bought this.
B
Bernhard Nemcsek
Ein top Gerät
Hab bis jetzt jedes Messer scharf bekommen 👍👍👍👍
A
Axel Strobel
Besser gehts nicht
Ich habe schon mehrere Messerschleifgeräte probiert. Aber Tormek liefert einfach das beste Ergebnis. Tomaten kann man hauchdünn schneiden
K
Klaus Kindschuh
Super Messerschärfer
Sehr gutes Schärfgerät
Getting started with Tormek T-1 Kitchen Knife Sharpener
Med Tormek T-1 Kitchen Knife Sharpener är det enkelt att komma igång och slipa dina köksknivar – hemma i ditt eget kök.
Se videon på svenska
