Conical Diamond Wheel Fine
Sale priceCHF 148.00
The Tormek T-1 Kitchen Knife Sharpener is supplied with the Conical Diamond Wheel Fine fully assembled and ready to use. However, if your diamond wheel gets damaged or worn out it can be replaced with this spare part.
How long does the diamond wheel for the T-1 last?
The diamond wheel (DF-150) lasts for thousand plus sharpenings. It is not possible to give a precise answer because it depends on how the diamond wheel is used. In the vast majority of households, it will allow you to sharpen your knives for a lifetime, or more. The finish of the diamond wheel will get finer and finer over time and if you ever want to replace it with a brand new one, we recommend keeping the earlier one for times when you want an extra fine finish.
You can see how to replace the diamond wheel in the manual for the Tormek T-1 Kitchen Knife Sharpener.
