- Regular price
- €370,00 EUR
- Regular price
- Sale price
- €370,00 EUR
- Unit price
- per
In stock – Estimated delivery within 2–5 working days
Couldn't load pickup availability
The first real knife sharpener for the home chef. Unlike a simpler sharpener, hand lapper or honing steel, it sharpens the entire bevel of the knife, not just the outer edge. With the Tormek T-1 Kitchen Knife Sharpener, you’ll never have to take your knives away for sharpening – you can easily get them to professional sharpness yourself in a matter of minutes. At home in your own kitchen.
Selected Features
- stepless edge angle setting
- Fine graded diamond wheel for professional results
- composite honing wheel with integrated polishing agent for razorblade sharp results
- Minimal material removal – you don't grind away more steel than necessary
- Quiet running – only 45 dB
- Powder-coated housing fully cast in zinc, with a sturdy oak handle.
- 8-year warranty – 5 years + 3 years extra with online registration.
Home Chefs Deserve Professional Sharpness Too
Tormek has been developing sharpening machines for professional kitchens for many years. The highly regarded Tormek T-2 Pro Kitchen sharpening machine is used by the Swedish Culinary Team and several Michelin star restaurants. Using this experience, Tormek has now developed the first real knife sharpener for the home chef.
The T-1 Kitchen Knife Sharpener has a sleek, subtly industrial design that gives it a natural place in the modern kitchen. Because whether you're cooking in a restaurant or at home in your own kitchen, the chef's most important tool is not a knife, but a real knife sharpener.
Tecnical info
Tecnical info
MEASUREMENTS
Width 204 mm
Length196 mm
Height 181 mm
incl. package 6,2 kg
Only machine 5,4 kg
GRINDING WHEEL
∅ 150 × 18 mm
Max 200 varv/min
HONING WHEEL
Komposit, ABS-plast
∅ 160 × 30 mm
HOUSING
Precision-cast housing in powder-coated zinc.
Bottom in impact-resistant ABS plastic.
Handle in solid oak
MOTOR
Enfas AC-motor
120 W (ineffekt)
Run max 30 min/hour
Maintenance-free
Quiet, 45 dB
10 000 hours operating time
CORD LENGTH
1,7 m
PATENT
To see all patents visit
tormek.com/patents
Knife Protection Pads – One additional set
Edge Protecion – 1st 30x305 mm, 1st 60x305 mm
Information for Getting Started
TRY THIS AT HOME
The fine diamond wheel is optimized for razorblade-sharpners. That's why a word of warning is in order – there's a good chance this will become your new favorite gadget.
1. SET THE CHOSEN ANGLE
17° is a good angle to start from if you're not sure which angle to choose. A small angle will cut more easily, while a large angle will produce a more durable edge.
2. SHARPEN THE KNIFE ON BOTH SIDES
Follow the edge of the knive and use little pressure, like you were cutting a tomato.
3. HONE FOR SHARP EDGES
Hone the burr away and polish your knife on the honingwheel for really sharp edges.
