- Regular price
- €6,00 EUR
- Regular price
- Sale price
- €6,00 EUR
- Unit price
- per
The knife protection pads comes applied on the patented angle guide of the Tormek T-1 Kitchen Knife Sharpener and collects steel particles when sharpening. They protect the blade from scratches so you can sharpen your most precious knives. If the pads are worn out you can easily replace them yourself with this set of pads.
- Protects your most precious knives from scratches.
- The package contains two pairs of knife protection pads.
Tip: Use a vacuum cleaner to remove steel particles collected in the pads.
Easy to replace
New knife protection pads can be applied by removing the patented guide from the machine and disassembling the clamp off the guide. Then easily remove the old pads from each part of the guide and replace with a new one. Please note that the two pads have different shapes and will only fit correctly on the part of the guide that has the corresponding shape. Instructions on replacing the pads can be found in the manual of the T-1 Kitchen Knife Sharpener.
