  • Tormek T-1 Kitchen Knife Sharpener (bara maskinen)
  • Magnet som samlar upp stålpartiklar från slipningen och patenterad styrning. Tormek T-1
  • Knivslipen för hemmakocken med finkornig diamantslipskiva för professionellt resultat.
  • Rejält trähandtag i massiv ek behandlad med hårdvaxolja.
  • Tormek T-1 Kitchen Knife Sharpener har en snygg, subtilt industriell design som ger den en given plats i köket.
  • Patenterad styrning med steglös inställning av eggvinkeln.
  • Tormek T-1 med separat bryning på brynskiva i kompositmaterial med integrerat polermedel.
  • Tormek T-1 3D-model
1 of 10
Regular price
€370,00 EUR
Regular price
Sale price
€370,00 EUR
Tax included. Shipping calculated at checkout.
The first real knife sharpener for the home chef. Unlike a simpler sharpener, hand lapper or honing steel, it sharpens the entire bevel of the knife, not just the outer edge. With the Tormek T-1 Kitchen Knife Sharpener, you’ll never have to send your knives out for sharpening – you can easily get them to professional sharpness yourself in a matter of minutes. At home in your own kitchen.
Selected Features
  • Precise setting of the sharpening angle with the patented guide.
  • Fine-grained diamond grinding wheel for professional results.
  • Composite honing wheel with integrated polishing agent for razor sharpness.
  • Minimal material removal – you don't grind away more steel than necessary.
  • Quiet running – only 45 dB
  • Powder-coated housing fully cast in zinc, with a sturdy oak handle.
  • 8-year warranty – 5 years + 3 years extra with online registration (for household use only).
Home Chefs Deserve Professional Sharpness Too
The T-1 Kitchen Knife Sharpener has a sleek, subtly industrial design that gives it a natural place in the modern kitchen. Because whether you're cooking in a restaurant or at home in your own kitchen, the chef's most important tool is not a knife, but a real knife sharpener.
Sharpen your kitchen knives
With its innovative design and the best materials, the Tormek T-1 Kitchen Knife Sharpener can sharpen most types of kitchen knives. The patented guide can handle knives with blades 12–60 millimeters (0.5–2.4 inches) high and up to 5 millimeters (0.2 inches) thick, with unlimited length. The fine-grained diamond grinding wheel sharpens all types of steel to professional sharpness and can also sharpen ceramic knives.
Quality and Care
The Tormek T-1 Kitchen Knife Sharpener is designed for those who care about quality and want to take care of their equipment. The machine is built to last and comes with an eight-year warranty, but will likely keep you sharp for much longer than that. With minimal steel wear, the life of your knives will be extended, and it will always be a pleasure to use freshly sharpened, razor-sharp knives in the kitchen. That's why a word of warning is in order: there's a good chance this will become your new favourite gadget.
Technical specifications
MEASUREMENTS
Width 204 mm (8")
Depth 196 mm (7 ¾")
Height 181 mm (7 1/8")
WEIGHT
Incl. packaging 6.2 kg (13.7 lbs)
Machine only 5.4 kg (11.9 lbs)
GRINDING WHEEL
∅ 150 × 18 mm (5 7/8" × 5/8")
Max 200 rpm
HONING WHEEL
Composite, ABS plastic
∅ 160 × 30 mm (6 ¼" × 1 3/16")
HOUSING
Precision-cast housing in powder-coated zinc
Bottom in impact-resistant plastic
Handle in solid oak treated with hard wax oil
MOTOR
Single-phase, AC-motor
120 W (input power)
Recommended operation 30 min/h
Maintenance-free
Quiet running, 45 dB
10 000 operating hours
CORD LENGTH
1,7 m
PATENT
To see all patents, please visit
tormek.com/patents
Knife Protection Pads – One additional set
Edge Protecion – 1x 30x305 mm, 1x 60x305 mm
Instruction
Getting Started information
TRY THIS AT HOME
The fine-grained diamond wheel is optimized for razor-like sharpness, so we have just one small warning: There is a major risk this will become your new favorite gadget!
  • 1. SET PREFERRED EDGE ANGLE
  • 2. SHARPEN ON BOTH SIDES
  • 3. HONE TO A FINAL FINISH
    Remove the burr and polish the knife on the honing wheel to achieve a razor-sharp edge.
Customer Reviews
Based on 503 reviews
81%
(405)
11%
(57)
3%
(17)
1%
(6)
4%
(18)
K
Kalle Karlsson
Ggg
H
Hugo Van vliet
As use it “professionaly “Great until now , will see in the long Time
P
Pascal Jacobi
Stay sharp!
Love it! A beauty with amazing results 🙌🏻👌🏻
L
Lloyd Alegre
I love it
A
Axel Bittner
J
Jens Hövelmann
Endlich wieder scharfe Messer
Meine Messer wurden über die Zeit immer stumpfer, der Wetzstahl reicht eben irgendwann nicht mehr aus. Ein handgeführter Messerschleifer führte auch nicht zum gewünschten Erfolg, den Rollschleifer von Horl finde ich einen Hingucker, aber ist der wirklich praktisch? Als mir dann der Tormek T-1 aufgefallen ist, war ich sofort angefixt. Echter Maschinenbau, runterskalierte Profi-Technik zu einem Preis in der gleichen Größenordnung wie die Konkurrenz.
Und was soll ich sagen: Endlich wieder scharfe Messer!
Danke auch für die Pflaster als "Dreingabe" - eines habe ich schon gebraucht, weil ich die Schärfe unterschätzt hatte.
