Morakniv Classic 1891 Paring Knife
Sale price355,00 zł
I lager - Leveranstid 1-3 arbetsdagar
The paring knife is the kitchen’s smallest hero – perfect for handling small ingredients with great precision. Like all Morakniv knives, it is manufactured in Mora, Sweden. Peel fruits and vegetables easily and smoothly, and make precise cuts with full control over every movement. With its beetroot-stained Swedish birch handle and sharp Swedish stainless steel blade, this neat kitchen knife is designed to give you the best possible conditions for success.
The 8 cm long polished blade is forged from Swedish stainless steel, 10C28Mo2, with a recycling rate of over 80%. The high-quality steel makes it possible to achieve razor-sharp edges and has a chemical composition that provides excellent corrosion resistance. Each blade is side-ground with the utmost precision and finished with a fine honing of the edge, resulting in a total edge angle of 36 degrees – 18 degrees per side.
Find more knives from Morakniv here.
