guide
Sharpening guide Test
The Tormek T-2 Pro Kitchen Knife Sharpener can make all your kitchen knives sharper than new in no time. But did you know that the SC-60 Scissors Jig allows you to also sharpen virtually any pair of scissors you might find? The jig is designed to give controlled, consistent results on your kitchen scissors, quick and easy. This guide walks you through setup, technique, and practical considerations so chefs and kitchen staff can restore clean, precise scissor edges with minimal effort.
Why the SC-60 Scissors Jig?
  • Repeatable edge geometry
  • Minimal steel removal
  • Clean, sharp results
Step 1 – Prepare the Scissors
Availability
Scopri di più
Commercial Product Test
Woodworking Test
