Tormek T-1 Morakniv 1891 - Linen White (CH)
The Tormek T-1 Morakniv 1891 is launched in conjunction with the relaunch of the highly regarded kitchen knife series, Morakniv Classic 1891. You can purchase the machine as it is or as a package with the Morakniv x Tormek collaboration-branded Morakniv Classic 1891 All Knife. If you already have your Tormek T-1 and just want to get the knife, that's also possible. The Morakniv Utility Knife Classic 1891 is sharpened to 18 degrees on each side. The Tormek T-1 Morakniv 1891 is available in Zinc Gray.
Knife Protection Pads - One extra set
Edge protection - 1st 30x305 mm, 1st 60x305 mm
Edge Marker - A Tormek Marke for Color the Bevel.
Chord length
5' 7” (1.7 m)
Ø 5 7/8" × 5/8" (150 × 18 mm)
RPM
Max 200 RPM
Ø 6 ¼" × 1 3/16" (160 × 30 mm)
Composite, ABS plastic
One-phase, AC motor
Input power: idle 60 W, max load 120 W
