guide
Sharpening guide Test
Tormek T-1 Kitchen Knife Sharperner Swedish redTormek T-1 Kitchen Knife Sharperner Swedish redTormek T-1 Kitchen Knife Sharperner Swedish redTormek T-1 in Swedish Red with Birch handleTormek T-1 Kitchen Knife Sharperner Swedish red
Why the SC-60 Scissors Jig?
  • Repeatable edge geometry
  • Minimal steel removal
  • Clean, sharp results
Step 1 – Prepare the Scissors
Sharpening a knife on Tormek T-1 Morakniv 1891 Linen WhiteTormek T-1 Morakniv 1891 - Linen White in a holiday setting
Availability
Puede que te interese
Commercial Product Test
Woodworking Test
